just installed ultimate chip and 3bar map sensor
typhoon92
i just installed ultimate chip and 3bar map sensor and i took my ty for test drive.once i start building boost and it starts to ping at any setting at t-1 ---t-2---and at t-3. do you guys think it could be the map sensor? or what could it be?
sam
92 ty #0438
sy112
i guess I will take a stab, TO MUCH TIMING and/or NOT ENOUGH FUEL :x
The Ultimate has more aggressive timing than stock cals. T1 you might get away with but T2 and T3 you are lucky you didn't kill your motor on pump gas.
Do you have a scan tool? If not I advise you to put the Ultimate down and walk away slowly :lol: Seriously, you need a scan tool to monitor when you mod.
Did you adjust the FP to compensate for the Ultimate?
If you are going to keep running the Ultimate keep it on T1 until you figure it out.
Not trying to be an ass but use the search function and research stuff before you bolt it on.
My advise: put the Ultimate back in the box, put everything stock, buy a scantool, get it running perfect before even looking at the Ultimate again.
With great power comes great responsibility young grasshopper :wink:
sy112
I know my Ultimate V7 runs best off about 48 #'s of FP, not exactly sure what the V8 (which I assume he has) requires, but I'm sure so tweaking is in order :wink:
typhoon92
thanks guys for your response. i do not have a scan tool but where is a good place to buy one? before i installed the ultimate 7 it ran fine with no ping while building boost . so you guys are think it's my fuel presure that needs to be turned up ? how much much presure should i be running?
sam
92 ty #0438
jwaller
Evil Genius/SyTy Guru
part of installing the ultimate is that you HAVET TO change the FP. 47-50 is a great starting point.
but you have to have an adjustable regulator to do this. do you have one?
sy112
as far as scan tool, go to e-bay a get a cheap laptop there, usually under 400 bucks. Make sure and get one with a serial port or you will have hell will serial port adaptors. The connection cables require a serial port. Then got to Datamaster's website, not sure what it is, but someone will chime in. Buy Datamaster, it is the best, hands down. I have turbo-link and am planning on switching to DM as soon as I can.
So know we know you have V7, which is good, T1 the lowest timing setting is stil a lot more agressive than stock, you need more fuel. That is probably your culprit.
If you haven't done it yet, you need to do a complete tune-up, cap, rotor, plugs , wires, chack all vacuum hoses, etc. The Ultimate is a great setup, I love mine, but i gets a lot more performance than stock and will emphasize any weakness in your tune-up.
go here: http://sportmachines.com/maintenance/beginner.php
follow to the letter of the law, at least as far as maintenance, and she will run a lot better.
Once again, YOU NEED A SCANTOOL!!!! Don't let the cost deter you, it will be the best investment you have ever made. It will help save you from killing you truck as well as helping you get the most out of it as far as performance.
good luck
smeagol
Not really.... and V8 & 9 are even less aggressive than stock, with other safety concerns built in.
InvisiBill
Look around. I posted in Off Topic about a brand new 2GHz Dell laptop for $674. I have an old just-meets-the-minimums laptop that I keep in the Sy for running DM, but it will run so much better on a new one. Plus you can use it for other stuff (it's possibly even better than your current main PC). You may not want to spend the extra $300, but that $674 laptop is a much better overall value than most of the old used "cheap" stuff you find for sale.
sy112
good point BG, what I meant was at least we know exactly what version he was running, not necessarily which version was better.
