kb a/a ic pipe popping off
jbone
I finally got the ic installed and everything was going great until tonight. At wot stock boost the ic pipe popped off at the intake manifold and it kept doing it for the rest off the night under low boost. maybe 3-5 pounds. The clamps were cranked down tight to begin with. any ideas on how to fix it?
chelo
filthy sy
Re: kb a/a ic pipe popping off
you might have to fabricate a bracket to hold both together. Or you can add some small bead like welds to the tb.
berzerker
wookie
get some good clamps !!! t-bolt clamps from a heavy duty truck dealership is what u want .
My:2cents: is there's something else wrong. Clamps? Yup. But also the hose itself can get frayed in the inside once this happens even once. I'd also be suspicious of an undetected over boost. Point is, that thing isn't comming off on its own, there's good reason somewhere. I'm assuming stock IC. IMO if the mounting bolts aren't supporting the stock IC correctly then this might also occur. Aftermarket A2A? As mentioned, lots of folks make a set of brackets that locks the pipe and manifold together.
jbone
does anyone have pics of these brackets? That may be what the extra piece was for that I couldnt figure out how it went on b ut ill try again. thanks for the help.
Robert Lone
MUTANT
With 28psi and 2 radiator hose clamps hooked together, my pipe didn't pop off mine w/ the KB A2A.
But then again, the engine didn't survive. I'd have to agree w/ Don that you may have an overboost prob or something else gone wrong.
Here's the backyard engineering on mine.
I'm sure that yours doesn't look like mine but it's still the same hose. Don't pay any attention to the rust and funk. this was from the first drive in my truck. :lol:
EDIT: The 2 hose clamps were hooked together to make 1 big hose clamp big enough to go around the TB hose. Not hooked together as a retaining device. You can also see 1/2 of the bracket that attatches the pipe to the TB in the second pic. It's the tab coming off of the top of the pipe near the TB.
Flyin Ryan
hated cuz he drives fords
Most people useally add a bead of metal around the edge of the pipe so that it has something to grab onto the silicone coupling better.. and yes you should have nice clamps as well
jbone
ok I finally figured out where the braket went that keeps it attached to the tb. So I shouldnt have a prob anymore. according to my stock and aftermarket boost gauges I wasnt over boosting at all, and I cant find any indication that theres a prob. So Im gonna run it again and see what happens. Another prob I came across was the intake. I had an atr but I doesnt fit anymore with the ic plumbing so I just threw the stocker back on. It may just be psychological but the truck feels kinda slow. Not sure if its slower than before but idk. Thanks again for the help guys
jbone
Its insane ever since I put this thing on ive been asked to race about half a dozen cars shame is they are all like 10-11 sec cars :roll: so I just tell them its not worth wasting their gas. Its jsut that I havent been able to find a good race in months and now I cant get people to leave me alone.
