Keyless entry not working
TGO
I figured the battery was just dead in the remote but apparently that's not the case.
I followed the instructions on how to reprogram the remote to the car but it doesn't work.
Jumping pin G to A in the connector under the dash does nothing. Neither does just grounding pin G.
Assuming all Typhoons came with RKE, I'm guessing the module is just dead?
Is there anywhere you can buy them refurbished or something?
Slyclone
Well-known member
Re: Keyless entry not working
Did you check any fuses? See if anything is not getting power?
TGO
I don't know what fuse is for the RKE module.
Power locks work ok.
