Keyless Entry On A Syclone
I am starting this in thread in hopes to get some answers about putting a keyless entry system in a Syclone. I have read tons of threads on here but none mention how to convert the old 5 wire system on the sy to a 92+ system so you can add the RKE. I currently have a brand new RKE from a 95 S-10, sierra, sonoma. Basically any 2 door truck gm made from years 93 to 96. The part number on the RKE is GM# 15955703. I also have the 2 button remotes # 15725422 that work with it and of course the power door lock relay. I have everything wired pretty much but have no clue how to modify the door lock 5 wire system. Any answers would be greatly appreciated! :tup: Also if anyone has a way to tell me which wires go to which pins in the RKE would help alot too and appreciated!
canadian
sy in progress
Re: Keyless Entry On A Syclone
I think you'd need to pull the entire door lock harness from a car with a 5 wire system. I don't believe it's as easy as adding 2 wires.
Actually the problem is the syclone has the 5 wire door lock system. To be able to add the RKE you have to modify it to except the newer 3 wire system. That is my huge problem. I know it has been done but not sure how to do it. I know it involves something with the door lock switch and doing something with the 3 black wires that go to the switch but not sure what.
autoaddictions
cant you just find the negative or positive output on the keyless and use 2 relays in a five wire configuration? If the gm system wont work get a aftermarket keyless they are cheap. under 50 bucks.
canadian
sy in progress
I know DaveP on here has done some wok on putting a keyless system into a Syclone or S10 daily driver. I had a complete GM system that I donated to him as it would have been more of a pain in the ass to try and get it to work with my Sy than it would have been to buy an aftermarket system.
I say cut your losses and go with an aftermarket system designed to work with the door locks. I believe most GM alarms are just re-branded aftermarket systems anyways.
Actually I did talk to Dave, he has helped out before. Hopefully Dave will see this and give me some advice as I do know he has done the door lock rewire. DAVE WERE YA AT MAN!! :D
With the factory system i'm installing it uses the one relay which I already have. You might be able to use 2 but I know there is a way to modify it to 3 wire. Call me old school but I really want a factory keyless system :tup:
I have done two of these retro-fits. They are not difficult if you have the wiring diagrams, and have a basic understanding of how it should work. One of them I did without removing the IP. I did all my interfacing at the connector above the parking brake. There are 6 wires of interest in that connector:
orn/blk = Battery + Hot at all times. From PWR ACCY Breaker
Large blk = Ground
smaller blk = un-lock
lt blu = lock
gry = lock power to motors
tan = un-lock power to motors Note on the tan wire: The tan for the Drivers door motor goes directly to the tan on the RKE module. The tan for the Passenger door motor goes to the tan on the relay.
For the door switches:
Drivers Door: There are three black wires. Term B and E are chassis ground. Remove these, and tape them off. Leave the others alone. The remaining black is the "unlock" mentioned above.
Passenger Door: Remove the gry and tan wires from the switch and tape them off. Leave the others alone.
If your RKE and lock relay have the factory pigtails, wire all the colors like to like (paying attention to the driver's tan wire) between the componets, and it should work. It's not that hard.
Let me know if you need more,
DaveP
Dave,
You are the man! Thank you very much for that info. I already got it rewired. I ordered 2 new pigtails for the RKE Module and they should be here within the next day or so. As soon as I get them connected to the module I will let you know how it all turns out. Once again thank you, everything else is easy but that 5 wire deal stumped me so THANK YOU!! :tup:
Like this? If you look closely, the connectors for the module have the letters embossed by the pins.
Yes it do like it, it is gonna help out alot! I got a few things to ask though. The 1992 RKE wires doesn't look like it's the same as my 1995 chevy s-10 RKE. I am going to post a few diagrams for the 95 S-10 Keyless system. I wrote on the connector page of were it looks like the wires need to go into what pins on my RKE.. Not a 100% sure though, could you look and see if i'm missing anything. I don't anna hook it up wrong and waist a ton of money to replace something that could have been prevented.. Thank you again, you have been tons of help!! Hopefully this info might help out someone else interested in doing the samething. It is time consuming but well worth it! :tup:
The pin-outs on your module are different, I guess. How would I know that? I'm just a hobbyist, not a magician. I've always used SyTy or 1st gen stuff for my projects. It looks like the schematic and wire colors vs function are the same. I took my diagram down so as not to cause confusion.
If you have access to AllData why are you bugging me for info? You obviously have resources for obtaining info. Especially for components none of us here are familiar with.
I'm sorry, wasn't trying to upset you. I am too a hobbyist and far from an expert. I was able to get the dealership to give me a copy of this and I had to beg big time to get that so no I don't have unlimited access to alldata. And that schematic you put up did help out big time. Wire colors and pins were not all the same so between your diagram and what I could get from the dealership I now can get it all wired up right. I'm sorry if I pissed you off, I was just in need of some information and you did answer it for me so thank you again. You were a huge help and did answer questions nobody else could!
