Kinugawa Turbo replacement feedback
TYTILIDIE
METH HEAD
So I bought a cartridge (20g) from ebay. It is made by Kinugawa, a company from Taiwan. I installed the cartridge today and so far, don't have anything good to say. Physically, the wheels appeared to be identical. The only difference I can see ( and I looked hard ) is that the fins on the wheels are thicker. Other than that EVERYTHING looked identical. So I get this thing all back together and took it for a ride. So far my only complaint is that it will not make more than 10psi. I'm not sure if it has a break in period or what and I have never heard of a turbo needing to be broken in. I'm going to give it a couple of days and see how it goes. We'll see what happens. I am wondering if the additional weight on the fins is slowing it down.
socalblue
Re: Kinugawa Turbo replacement feedback
I was thinking about buying a re-build kit on e-bay, and all they seem to sell are these aftermarket company stuff and I'm real sketchy on these...e-bay has let me down many times so I'm just going to take it in to a turbo re-build shop and ask to see that they use genuine oem parts.
But yea, keep us updated on that cartridge please!
It's just a six
Super Member
You should be able to boost it higher than 10 psi,even if the wheels are heavier, seems like some sort of boost control problem.
You can say one good thing, the 20G cartridge cost much less than a Mitsubishi 20G one. But if it blows up in a short time, then dont say any good things.
Should take it a little easy on a new cartridge for a few miles @ least. :2cents:
TYTILIDIE
METH HEAD
You can ay one good thing, the 20G cartridge cost much less than a Mitsubishi 20G one. But if it blows up in a short time, then dont say any good things.
I don't agree with that. It says in the description that it was spun at 180,000 RPM, to ensure that it is a good working unit. If that is the case, that should should be break in enough. Either way I have NEVER taken it easy on a new turbo and never had a problem. If it is a boost control issue I don't know what it could be because nothing has changed between the install. I suppose I could try another solenoid and see if that helps but somehow I doubt it.
If it "wakes up" after a few hundred miles and all ends up well, I will totally eat my words but, I wanted to make this thread a detailed description of one of th4ese things.
qbnkiller
Conflaguration Specialist
within a few minutes of startup, that turbo will be ready for whatever you throw at it if it was built / clearanced properly.
bezerk
correct, an new turbo can be used as an old turbo, oil temp needs to be good in any engine and esp. a turbo one.
we have a tractor workshop, it woudl be pretty hard to say to a costumer..sorry we replaced your turbo, but please don't use the horsepower whole day long. you need to break it in for a few days
TYTILIDIE
METH HEAD
Absolutely positively, no boost leaks. That is indeed the company. I don't see why the thicker wheel wouldn't slow it down. I mean, lightweight engine parts can result in higher RPM' right? Everyone wants everything lighter for a reason. I think it is the thick wheel causing the problem. It used to be when I drove up my driveway and shut the truck off I could still hear the turbo spin for a bit. Was even kind of loud. Now, It doesn't make any sound. BOV is WAY quieter. Getting in to boost is half a struggle. I'm giving this thing til the end of next week before I ask for my money back,m which I'm sure I wont get.
It's just a six
Super Member
Yes, having a heavy turbine shaft,wheel & compressor will will slow down/increase spool-up time, but once it gets spooling up it should deliver your boost goals.
I bought a cheap Ebay 60-1 compressor wheel & installed it onto my 20G turbine wheel, & the Co. that carved/machined the compressor housing to match the 60-1 wheel was not good @ all & the clearances are excessive, still it can boost easy 25 or more PSI & I also bought a cheap TD06H rebuild kit from Ebay,no complaints from my end so far about the cheap $ parts,, just the crappy machine work that Company did on my compressor housing.:rant:
The only way it won't get a lot of boost is not because the wheels are thicker or heavier,,, has to be a very poorly designed or copy of a turbine wheel or compressor wheel or having installed a compressor wheel designed to spin backwards,but I would not think a backwards compressor wheel will give you any boost.
Are the clearances between the compressor wheel & compressor housing excessive?
Or the turbine wheel clearances too great or both?
A turbocharger is just a devise to pump air & if the clearances are too big,effieciency will drop off greatly.
I am pretty sure you will find out why your not boosting like it should, sooner or later.
Goodluck!
Icarus-54
Donating Old Member
I bought their replacement compressor wheel for the 20g,the one with the thinner center section.I'm quite happy with it.It seems to spool quicker and feels like it pulls harder.
Those come with a built in governor. Hard to find. They hide it up inside the drain, Look for a little Allen screw that presses on a little brake pad against the shaft. Undo that and you'r good to go.
cat-vi
Ty Wannabe
Why in the world would they install anything like that? a brake function?
At higher altitudes like Colorado the turbine tends to over-speed but the factory has no way to properly adjust the governor because they're at sea level. Maybe even below sea level now. Anyway, they tend to set it to a conservative setting hence the low boost.
cat-vi
Ty Wannabe
Thanks, learning something every day in this community.:tup:
