Knock issue
WyoSyclone
Re: Knock issue
I think you've done a good job of eliminating as much of the knock as possible without doing a real-time custom tune.
That boost spike in third is a normal occurence with a modified motor and a basically stock chip. That shift is where the motor sees the highest change in load (big rpm change, aerodynamic load, etc.) - you've got a lot of heat in the exhaust manifolds at a relatively high rpm in second. When the shift occurs your're suddenly at a lower RPM with that same amount of heat - the hot gasses expanding as they pass through the turbine wheel/housing are a component of boost - velocity being the other. The increased load on the motor is fighting against that increased pressure/boost in the turbo/manifold section - a good recipe for increased knock.
Adjusting the wastegate rod will alter overall boost response throughout the rpm range... You'll be able to maximize boost once you get into Code59.
You'll also be able to maximize your timing once you switch to Code59.
You can try the top-end cleaner... it definitely won't hurt anything. It looks like you've simply ran up against the octane limit of your fuel.
I'd sure replace your dampener - if it's slipped it may have developed a wobble which is really hard on the bottom end. I'd also get a couple of 32 ounce cans of torco and dump into a full tank of premium - that will give you 102 octane and give you an opportunity to see what it does with that octane level before moving on to Alky. Just my :2cents: :D
sytyguy
Moderated User
Re: Knock issue
Couldn't agree more. Sean, it sounds like your at the point where going to code59 and doing some tuning for yourself is the missing link. The little tweaks here and there are what you need, and it makes it SO much easier when you're emulating and can make that change with a single keystroke.
