knock, knock...and other stuff
4C FED
Absolutum Dominium
Details: Stock motor with Ultimate for stock injectors/heads
Problem: Last year I had a problem where I started seeing knock & the TCC would lock & unlock in a steady cruise. I popped the Ultimate out & re-seated it into the carrier. I also lost the display on the radar box which I repaired by trimming the end of the ribbon cable that is inside the box and reattaching it (crimped or soldered I don't remember which) and the display came back, knock went away (able to run T1/20 setting with no knock & it actually went to 23psi) & TCC would behave normally.
Jump ahead to this year & now I am seeing knock again (T1/16 setting) with the same fuel (100 octane) as before, the TCC will sometimes chug badly right after it shifts into 4th, it basically runs like a pig & the idle will drop & is low IMO, ~600 rpm.
What I have found is that if I turn the truck off and start it again it will often times run correctly with all of the issues above gone.
I'm wondering if this is indicative of a problem with the Ultimate, if I have a flaky connection somewhere in the ECU or the ECU is bad?
Has anyone else had these symptoms?
Re: knock, knock...and other stuff
If your connection is flaky with the ultimate display, I would fixed that first. The carrier chip in the ultimate is larger than the stock chip, the PLC chip in the display, decodes the program and sends signal to the address line in the carrier chip depending on the program selected.
Basically the display chip and carrier chip need each others functionality
4C FED
Absolutum Dominium
After I fixed the display last year I have had no problems with the display.
The radar box is just velcroed below and to the left of the ashtray. Usually after several times of turning the keylock & switching back & forth from SEC to any of the programs it will come loose from the velcro. It usually settles into my hand since I have the key in it.
Maybe the repeated flexing of the ribbon cable has internally frayed the wires. I know we have this problem on some of the robots we use that have the same ribbon cable. The solution is to use some other flex cable that is much more durable & can handle loads of flexing without a breakdown of the conductors.
Is it possible for the display to still work & be able to toggle thru the programs, but yet there is a flaky connection in the ribbon cable?
Ultimate on T1 & 100 octane shouldn't knock IMO. Double check timing. Maybe pull down the ECM and reset all connections. Check connection at MAP sensor and TPS. :2cents:
4C FED
Absolutum Dominium
I pulled the ECU out before I left work last night. I re-seated the connectors, the memcal & the Ultimate.
I was unable to get more than 10psi out of it. I've never had any audible knock. My laptop battery was dead so I couldn't see what was going on with it.
Got home, checked timing. It was where I set it last time.
Installed another ECU with Pitbull chip & 2 bar map & set fuel pressure to 38psi. Seemed to be better, but my laptop still wasn't charged so I'll have to wait until Friday to do some more troubleshooting. I'm off to Slo-Cal for a few days.
4C FED
Absolutum Dominium
I replaced my cap & rotor today with a good used one I had saved. The Napa one had something funky going on with it at the center electrode. It wasn't making a good contact due to some plastic flashing around the center electrode.
Regardless, I still had some knock retard just reving the motor in park.
I figured I would adjust the valves because it has sounded noisy since I bought it. I used Don W.'s method. All of the valves were loose. They were all pretty much at zero lash or looser.
I must say that the difference with the acceleration is like night & day now.
But..... although it spools crazy fast, it also overboosts like a mofo & I have more knock retard. :rant:
I did notice something with the distributor today & I just realized what could be the problem with the knock. The #1 post on the dist. is rotated clockwise past the centerline of the motor, which tells me the dist. is in wrong & that I'm setting my timing to the wrong mark. Looks like I'm off a tooth. :squint:
turboj91
The fact that you may be off a tooth and the dist is clocked past the centerline is not the problem. If you are off a tooth you just move the dist to orientate the cap post with the rotor. If your timing is correct with the pointer and the balancer, it is correct whether or not you are off a tooth.
4C FED
Absolutum Dominium
Yeah, that makes sense. And my dial back timing light confirms the timing Tunerpro says it should be is what I see on the timing light.
I'm just trying to figure out why it runs so much stronger but the knock has increased.
I'm going to double-check my valve adjustments again in the morning & check my wastegate adjustment.
4C FED
Absolutum Dominium
Well after chasing my tail for a day & a half looking for what was causing a miss, I replaced the following:
plugs, wires, cap & rotor, ign. module, map, ECU, adjusted the valves & adjusted the valves again. I finally found that I somehow knocked one of the injector connectors off of #3 injector. :rant:
Now I'm back to figuring out why I still have some knock. :tdown:
Kinda hard to do that what with that major spring retainer clip thing each connector has. Are you sure they (the harness connectors) are all fully seated? Bunch of other suggestions already made. follow up on those. Can you post a DM run? Check WG actuator etc and make sure everything is free and has full travel.
Glad my valve adj procedure worked or you.:tup:
NecroWolf
lost marbles member
i don't think it's possible to be a tooth off on the distributor. the pin that dizzy connect to the oil pump prevents that. could it be false knock? loose timing chain? loose bolt on the trans lines where they bolt to the torque convetor cover?
4C FED
Absolutum Dominium
I thought so too. But I guess with removing the EGR solenoid/,map bracket I must have caught it just right.
Checked the wastegate it was free moving & set properly. Boost is stable without overboosting now.
I forgot to say that the reason it was overboosting was that the only piece of stock plumbing left on was the hard plastic line fron the wastgate solenoid to the wastegate actuator. Well, again, I managed to pull it off without noticing while removing the IC. :oops:
I could post a DM log, but where can I upload to?
4C FED
Absolutum Dominium
Tranny lines are braided steel now. They don't make contact anywhere with the trans or motor.
Along that train of thought, I have replaced the fuel line with braided steel. Yesterday I slipped some convoluted tubing over it so that it's not making any metal to metal contact near the knock sensor.
The dist drive gear is on the end of the dist. When you install the dist you can engage any gear you want. Turn the engine a little or allot to allow for oil pump engagement and the dist will drop in the rest of the way. (It may have already done that.) Bring engine to #1 compression, see which term on the dist cap the rotor is pointing to (that will now be #1 on the cap) install the remainder of the wires in order, fire the engine and set timing with a light and you are done. The wires on the cap may or may not be in their "factory" locations but it will be in-time and run correctly, at least as-far-as timing is concerned.
HTH
DaveP6999 said:
There is a 'dimple' on the dist gear. Install the gear with this dimple and the rotor tip aligned, for 'factory' orientation.
DaveP
Thanks,
Just confirms something I heard once. There is a reason everything, be it dimple, some weird casting mark, you name it. The factory wouldn't put it there if it didn't have a purpose.
4C FED
Absolutum Dominium
Well I decided to go ahead & install the Walbro & Racetronix harness I've had sitting around for a year just to make sure the pump wasn't a problem.
Stock pump still installed. Took me 3 hours, pump & harness, start to finish. Much easier to do than on the Syclone.
Knock still present. Will post a DM log once I get the file hosted.
4C FED
Absolutum Dominium
4C FED said:
No love? :(
Update: I got a wild hair last night & decided to take off the stock IC & replace it with the ATR that I prevoiusly removed. I put the stock IC on recently so that I could install the Alky Control system since there isn't any room on the IC outlet to fit the nozzle.
I also wanted to re-route my IC lines which I had just run through the pass. fenderwell. I wasn't happy with how tight the fit was through there & since I have the ATR CAI I felt that the added space might be restricting some airflow into the fender plus the lines have some tight spaces to navigate.
When I droppped the lower heat exchanger I found that the Johnson pump had rotated in the clamp & had caused a kink in the 90 deg. hose from the pump the the heat exchanger. This is probably why my IAT's climbed quickly during a run. I doubt that it was causing my knock when reving it in park.
So the IC lines went back across the drivers side to where I had them previously. I also opened up the water inlet & outlets on the ATR IC to 1/2"npt from the normal 3/8"npt and added the correct 3/4" hose barbs on the IC. No time to test drive last night as it was late when I finished.
I filled up with 100 octane gas again this morning & made a quick run. I had no knock on the T1-17 program this time, although I only hit 13psi, so I need to figure out why the boost was low.
I tried switching to the T2-17 program and imediately saw 5 degrees of KR with only moderate acceleration.
Tooky
Serious about performance
I looked at your DataMaster file. It sounds like you covered all your bases. It even appears like your WB02 Datalogging is in the file and flawless at 11.8. Your RPM line indicates to me that it's not a stock converter. What converter are you running?
The boost control is also outrageously bad. Have you considered trying a manual boost controller like the BoostValve.com ball-and-spring unit like I run? I also don't know what turbo you have.
The knock does seem to rise with boost but that doesn't "guarantee" it's still not false, possibly.
