Ric1319
I'm still trying to figure out what the knocking noise is on my truck (93 Typhoon). I just finished replacing the oil pan gasket so when I had it all apart I look everything over it all looked good no shavings oil filter was clean bottom of pan was clean. So before I put it all together I decided to start it and warm it up. The oil pan was reinstalled and filled, coolant was filled also. I started the truck it was running great nice and quite when it warmed it started knocking. I still had the front diff out so I stuck my big head in the space between the oil pan and frame and heard the knock near the front. So I shut the truck off and removed the belt to see if it is something with the belt the noise got louder. :rant: Has anyone ever have a torsional damper go bad and if so does it sound like a rod knock. I think tomorrow I will go to an auto parts store and rent a puller and check it out. The truck sat for 18 years and a lot of the rubber was dry rotted maybe the rubber in this went bad, I don't know.:banghead::
