I am getting Knock Retard on my Diacom runs. I look through one of my files and I am only getting one knock count on the 1-2 shift, but my compter is taking out timing 1-2 degree all through 1st gear and an additional 1-2 in 2nd (total of 4 degree) What else is could cause the ECU to take out timing? (BTW this particular is with the stock chip/2bar map)
I am still trying to figuire out why my ECU is taking out KR
Ignore the problem below...
With my 3 bar map sensor, I thought I was over boosting, because my Daicom said so. Since installing a new boost/vacuum gauge (I though my first boost gauge was off) and fuel pressure gauge, I don't believe the Diacom pressure reading. For instance I on one run my peak boost was suposedly 17psi, but I never hit over 13psi on the boost gauge and my fuel pressure gauge agrees with my boost gauge. With the Ulimate/3bar My truck appears to be hitting only 9psi in 1st gear and after a while 13psi at the top of second. (With stock chip and 2 bar, it hit 10psi in 1st and 14 in 2nd, and 15 in 3rd) Could my 3 bar map be bad or miscalibrated?
