I need help with my Knock Retard. I am getting a bunch of it (usually 14-16 degree by the top of first) with my T1-16 programming. On some of my track runs, I got a tons KR in 1st but it takes so long to ramp out, I don't get any additional KR until the top of 3rd.
I am running 93 octane and I have done a bunch of stuff to try to remedy it. It isn't false, I tried reloacting the knock sensor with the same result (the knock comes in the beginning of 2nd gear instead of top of first) and race gas does help. I don't any have ignition flutter at all. My truck finally idles very good. I use diacom and have some files.
This is what my truck has (I am sure I will forget some things)
-Conrad Cap and Rotor, UR6 gapped at 0.030, MSD 8.5 mm Wires All replace 1200 miles ago.
-TEDC CLeaner around 2K miles ago
-New A/C Delco Coil
-MSD 6AL (tested with and without)
-3-4K miles aog O2 sensor.
-Redid all the intake, TB gaskets and cleanout out the intake.
-1.6RR's I know the adjustment is right, I re-did it with the engine running.
-Tried swapping ECM's, same result
-Have higher output alternator same result.
-IC pump works, Soft lines, IC temps usually start off at around 110 degrees.
-Radiator temps around 160-165
-Doesn't overboost, does have Random Tech Cat.
-New knock sensor.
-I have a 255L walbro, the fuel pressure is set at 52psi (My BLM's are at 128) The FP gauge say the fuel pressure is holding properly and tracking under boost.
-Checked balancer with piston stop.
-professionally clean the injectors and had them flowed.
The only problem I know I have is a dead Park/Neutral switch. Also Sometimes I get a dip in the O2 mV (down ot 200mV or so) right at a launch, but it comes right back up (I am wonder if this is a delay)
The truck was 100% stock and untouch when I bought it. It has 48K miles on it, never been driven in snow and the previous owner claims it was never driven in the rain, (though that has changed), so its not rust and is very clean.
-New A/C Delco Coil
-New knock sensor.
