mrweelr
I have a simple question. The PLX-R500 wideband computer I use has a knock sensor input which I have hooked up. The voltage swing on the knock sensor is 0-5v and sometimes, I see little voltage spikes on the display screen while driving. I want to know how much KR various voltage outputs from the knock sensor correspond to. In other words, if I see a 1v value coming from the sensor, how much KR is the ECM applying? I don't always drive around with Datamaster hooked up, so knowing "how much" it's knocking would be quite useful. There's a red LED on the R500 that can be configured to light as desired. I want to set it to light when AFR is > 12.2 or thereabouts and/or knock sensor voltage is > ?? Any help would be appreciated.
