besides the new ultimate, is there a way to wire up or even buy a knock led indicator? i thought i read about this before somewhere.
i cant get the search function to work.
any ideas?
Take a look on Turbobuick.com, I believe most peeps use DATAMASTER to monitor knock. I know there is an actual gauge for the buicks thats available it has a turbo6 emblem on it. There was also some talk about this on our bbs some time ago (long LONG time ago) not sure where the information went considering you searched for it.
NOTE I tested the B8 pin in the ECM, and it did not work for me, so disregard this instruction for now. I have merely left it up here in case someone else has the ambition to double check my testing.
I’ve built this circuit and it does work. I wired it directly off of the Memcal.
The LED comes on when it see knock more knock more flashing.
The statement about wiring from the B8 pin in the ECM I did not try.
The little circuit is a thing I wrote up, based on a design from Barry Tisdale. I've had it on my truck for years and years. It's great. I believe it's this same design that is integrated into the next version of the Ultimate.
