Knock sensor question
Mad Mike
SYCOSIS
Will a code be thrown if the knock sensor is disconnected? After removing the ATR pitbull chip on my recently purchased typhoon I am still getting absolutely no knock readings with diacom. It's disconnected or an extremely good running truck.
KGB Pilot125
with your scan tool hooked up open up the hood and bang on the alt. bracket or the intake. with the handle of a screwdriver or a hammer on the bracket. you should be able to see if its hooked up then.
E-Rue
yeah what he said..... when in doubt i test mine by hitting the top of the throttle body with a ratchet. the metallic sound will trigger it perfectly.
e
