knock sensor question
NecroWolf
lost marbles member
being as i went with the newer vortec long block i can't bolt my knock sensor back in place, the threaded hole for the newer knock sensor is about half the size of the stock block one, would it be a problem to use a reducer to bolt it in or does anyone know of a knock sensor that will work? i know the brass sensor will mufle the knock sensor but i see ricers do this all the time so will it cause a problem?
KGB Pilot125
Re: knock sensor question
I would assume that if the connectors are the same you might be able to run a newer knock sensor. I know on my 1G eclipse the 2G knock sensor is actually better especially with the AEM standalone I am running. Other wise adding a reducer will probably make it not so sesitive, kinda like adding teflon tape to it.
NecroWolf
lost marbles member
the newer sensor is a two prong plug. guess i'll try and find a reducer. muffling it wouldn't be a bad thing right now since i have the 875 lifters and roller rockers
