So, if I have mine set at less torque, it will be less sensitive?
The knock sensor is supposed to be used with the matching knock module, I'm not sure that the Syty and lt1 knock module will physically swap. Also, it was the lt4 that had roller rockers, not the lt1. I know that the lt4 module is not interchangable as the lt4 is a obdII motor. I think trying other knock sensor combos would be risky and would likely not even work.
