KnockSensor
T
TurboBuick/GMC
Guest
I'm trying to find out if you can run a knock sensor on the typhoon and if so what kind do you guys run. I have a casper's knock gauge in my GrandNational and i would like to run the same in the typhoon. Any advice would very helpful.
ThankYou.
Falco
Are you aware that you have a factory knock sensor? You can even make a led, which will tell you when the ECM senses the knocking. It's incorporated into Ultimate II too...
Later,
tealty
Im gonna try the caspers knock gauge for buicks with a separate esc module. Im also going to tap a seperate sensor in the back of the block b/c i dont know if wiring the knock gauge to the OEM sensor will interfere with the signal the ecm receives from the OEM knock sensor. I'll let you all know if anyone is interested on how it works out.
later
jordan
tealty
did it work? What was his setup?......i've tried searching the BB and cant find anything on it.
thanks
jordan
