kr help (think its a tranny issue)
elorejas
What's can cause kr. I have swapped dist. Cap and rotor, wireset, sparkplugs,fuel pump, fpr and checked tha there's nothing hitting for false knock. Mods are egr delete,walboro, accufab fpr, rpm a2a, velosity chip. I do have the scanmaster 3 as well. I can't. Get the kr out of it sometimes its around 6 to sometimes 12. Any opinions count and it just sucks there's no shop or someone close to amarillo to take it to get fixed
elorejas
Re: kr help
Re: kr help
Forgot to add the afrs are around 10.5/11.0 at wot so it ain't lean. Boost goes up to 18 psi
johnboy89
Re: kr help
Re: kr help
Do you have datamaster? If not I would suggest getting it and post up the file to be looked at.
You could try some high octane gas or Xylene to see if it goes away, maybe turn the boost down some too? What Octane gas are you running?
I would advise not to run it hard with that much KR.
Re: kr help
Re: kr help
Try lowering the boost, 18psi is a lot of boost for stock turbo and pump gas.
You can also check the timing as well (and make sure the balance hasn't spun)
elorejas
Re: kr help
Re: kr help
ok thanks guys I will take that in consideration. since I started to DD it again when I got of work I ran it in drive and it runs great its at 0 the most it went up in a second was 2 KR but when I put it back in overdrive the KR goes all crazy. Any thoughts on that guys or maybe did this happen to someone else before. I did pick it up all the way to 100 at WOT with almost no KR any suggestions will be good thanks guys.
Big Mike
Re: kr help (think its a tranny issue)
Could be bad motor/trans mounts, when motor is torqued making trans selector arm rub on front prop shaft. Check that area for ware marks on shaft.
0966Sy
Code what?
The knock sensor grounds to the engine block, having a good ground from frame to block or head will help eliminate ground issues that can cause incorrect or erratic sensor readings
