L35 lower intake gaskets.
Syclone#2960
What ever it takes!!
Does someone have the part number for the L35 heads lower intake gaskets?
Autozone is showing Felpro MS93346-1 for the stock replacement. Is this correct?:p
Do I use the same stock LB4 heads intake gaskets?
Re: L35 lower intake gaskets.
I was going to use the stock gaskets. In about an hour or so, I will be in the attick and I will check how they line up for you...
Syclone#2960
Thanks guys, I did a search yesterday and found GM12529697 but none of the part store here could cross reference that GM part number. I do believe the stock ones will work. The victor renz part number is MS16154.
Syclone#2960
The Felpro part number is MS93346-1 the box states it replaces 12518285.
They look like a perfect fit for the L35 heads with the hump at the top of the ports.
The color is blue if this matters.
I have the stock ones that come in the Victor top end kit Michael Hood sells. The gasket fit the L35's ports perfectly except they don't have hump in the top of the gasket at the top of each intake port. The gasket is stamped with 14097298 (sounds like GM part number to me)
