L35 vs vortec heads
protechmn
just wanted to get some opinions from u members. I'm in the process of buying a set of heads for my ty. i found both a set of 10238181's and a set of vortec heads off of a 2003 4.3. I will be installing larger valves and springs on either set and im going to invest in getting either set ported professionally. my question is which would be the better choice, cost not being an issue as much as gains? i understand the vortec heads i would need to go no larger than 2.00 on the intake valve and i would also need modify the intake, i also understand they are more prone to detonation. i would appreciate any insite to help me make the better choice. thanx in advance.
BMFB
Not to scale
Re: L35 vs vortec heads
vortecs are a better choice for making power, but are more expensive. The l-35's will make more power than the stock heads, and seem to be less prone to detonation than the stock heads, but not as 'detonation resistant' as the vortecs. You can go fast with l-35s, but if you wanting 10's, vortecs get it done more easily.
If I recall, stock heads intake side flow something like 168 cfm, l-35's do 208, and vortecs do around a 222. totally wrong numbers, but ball park figures.
13Pelle
You can get into the 10's just fine with L35s....just ask Alex (qbnkiller). He was mid 10's with 35's.....
protechmn
thanx for the info guys i guess i will be going w the vortec's. is there only one casting # for these or will any work? now can any1 tell me a lil on what all i need to do the conversion as far as parts, i believe i need to install screw in studs, guide plates and adj. rockers..any1 have part #s for any of these items, as well as gasket pt #s. oh and what exactly needs to be modded on the intake or heads to bolt them on? i apologize for all the questions just wanna know what to expect...thanx again for the help.
warmpancakes
you need to modify lower intake thats the biggest part
Vortec ports are much taller, so it requires additional metal welded to top of ports. Heads then need drilled for the stock bolt pattern -vs- vortec pattern.
Lots of info on vortecs to be found with search button.
Quickstop [UK]
Combating adversyty.
Yes - that is what you need doing as well adding more material for the holes.
Search the site for vortec conversion as there is a tonne of info. Link in my sig to project thread has all my build stuff.
Comp Cams roller rockers, 1.5 ratio are as big as you need, kee the valves at 2" and you're all set.
Search for Tooky - he did a full vortec head install thread. :tup:
protechmn
thanx to all of u for the info. i will try the search and hopefully get answers to all my questions. thanx again...
BMFB
Not to scale
he did, but its only been done...a couple times at best, with extensive other modifications...and he had to grind so far into the runner he struck water (sorry alex)
Ty 1885
I would not install bigger valves! Performance diffrence is marginal, and MAY cause a crack between intake/ex. valves (happen more than ones before) !
Stock Vortec will easily flow 45cfm more on the intake side than L35's.
Unless you are really going to extensively port the heads, I am with Ty1885 on larger valves. If you want to put money into a set of Vortec's I would spend on performance 3 angle Valve Job and then nicer set of stock sized valves.
