Re: L35's or LB4's
1986 - 1991 LB4, ZR9 cam............ GM 10088148 w/o bal.shaft,. unequal cam lobe base circles
1992 - 1993 LB4, Z79 cam.............GM 10144176 w/o bal.shaft, equal cam lobe base circles
1992 - 1994 L35 cam.....................GM 10144047 bal. shaft, equal cam lobe base circles
1995 L35 cam...............................GM 10241693 bal. shaft, equal cam lobe base circles (same as 1992-1994)
My previous discussion was before I tried the ARP 100-7201 rocker studs and determined they will not permit a fully adjustable lifter pre-load . I removed the L35 heads and the ARP 100-7201 studs.and washers took my L35 heads back to my machinist. He drilled out and tapped the stud holes and installed 7/16" TimeSerts (BigSerts) for ARP 134-7101 rocker studs. .
I have a different valve train. My LB4 engine has a Comp Cams camshaft which has 1.190" diameter cam lobe base circles on the intake and exhaust lobes. . The 1987-1991 LB4 Z engines have cam lobe base circles that are 1.380" intake and 1.335" exhaust. ( I suppose that is to compensate for the valve rotators on the exhaust valves) The 1992-1995 L35 W engine has symmetrical cam lobe base circles that are both 1.260" diameter which makes the L35 net-lash lifter pre load setting impractical of not impossible. . The 1992-1995 L35 W engine has lifters that have a .117" pre load.at 20 lb. torque. The LB4 Z lifters have a ,060" pre-load.setting or about one turn. (.060" x 24 threads per inch = 1.44 - .500" for 1.5:1 rocker arms = .94 or about one turn )
I am using Comp Cam 875 "reduced travel lifters" which mean they have a lifter push rod seat that is .060" deeper at 2.600" height at zero pre load. Stock lifter push rod seats are at 2.660" height at zero pre load. . The Comp 875 lifters has a pre-load of only .004" pre-load or 1/8 turn from zero pre load. . The Comp Cams lifters combined with the Comp Cams 1.190" diameter (.070" smaller) cam lobe base circles along with the .056" higher push rod seat than a stock lifter, enables me to use Comp Cams 7940 chromemoly push rods that are 7.200" long and are the same same length as stock push rods. If you use your stock 1987 - 1991 LB4 Z cam and lifters, ARP 135-7101 rocker studs, with the 1992 - 1995 L35 W heads and camshaft, the LB4 Z push rods may be to short by .120" intake and .075" exhaust. That much difference in push rod length is beyond the range of your LB4 Z lifters (GM 5234890) which have adjustment range of .120" . The 1992-1995 L35 W lifters (GM 5234670) have .234" adjustment range and a net lash (non-adjustable) setting of .117" . However, the L35 lifters would have a adjustable pre load range from .077" to .157" with ARP-134-7101 rocker studs.. .
