PA L88 alum gm snowflake bbc heads
adam92
Re: L88 alum gm snowflake bbc heads
Can you list the date codes? Same casting number both heads?
Call the # in the ad,I don't have the heads in my possesion right now,they are at my buddies shop right now and I don't know all the casting #'s.
Nice heads! GLWS. AFAIK, these heads are somewhat rare and guys will usually pay a sizable amount for them.
blue83z
the 291 heads for LS6 and L78 Chevelle (454 450 hp and 396 350 hp) would probably go for 700 or 800 bare if they had decent date codes, those are cast not alumunum, and much higher production (several thousand cars).
These heads are much much more rare.
Just my $.02......pull the ad, get all the codes (dates), figure out what they are for and relist. You may be costing yourself a lot of money.
warmpancakes
what he said if they are un repaired and stock , depending on date code they might be worth up to 4500
blue83z
correction in my last post.....its 396 375 hp that used the 291 heads, not 350 hp. those were the standard 396's in 70 for most models.
