Chest Rockwell
For about a week now I've been chasing down a misfire on the Ty. At first it was just a higher-rpm miss, so I assumed it would be a cap/rotor issue, or maybe plugs. I started with the cap/rotor, and there were some burnt-looking contacts, so I thought that might solve the problem. Nope. Replaced the UR5's and checked the gap on the old ones. Old plugs were @ almost .040, so I was hoping that might explain rough idle and misfire. Gapped the new plugs @ .030 and tried again. Still missing, but now it's getting worse. At first it was high-rpm, after the plugs it seemed to stumble whenever it was in boost. Got to the point where any kind of pressure on the pedal caused the truck to miss and stumble. It ran ok when cold, but got much worse when warmed up, so I tried the ignition module. Problem still there. The next step is the fuel filter, and then fuel pump, since I've got one handy. I did a datamaster run last night. I was hoping to use the info on Tooky's site to figure something out, but it's still got me beat. I tried to attach the file, but this computer underway isn't letting me. Might be able to send if someone wants to take a look.
