larger oil filter?
Syclone#2960
What ever it takes!!
Re: larger oil filter?
Ive been using it as well & didnt realize it is the only option. Someone posted a comment a while back about a larger unit that would alow 5qts. Instead of 4.5qts.
sytyguy
Moderated User
The crucial parts of our filter are:
Thread: 18mm x 1.5
Gasket O.D.: 2.734"
Gasket Thickness: 0.226"
Micron Rating: 21
Type: Full Flow
Rate: 7-9 GPM
Burst Pressure: 325 psi
As long as you find a filter with those specs (or better on flow/micron/burst rating), then get one longer (our stock filter [WIX 51036] is 4.828" long). I'll look in the filter book on Monday, but if you find yourself at a parts store over the weekend, look in the back of their filter catalog, as most will have lube filters listed by thread (& OD, Length, etc...).
sy538
There is a smaller one, maybe a PF46, so when someone mentions the larger one I would guess they are talking about the PF52. GM has a ton of filters though, so there might be one even bigger.
edit
Didn't see Hood's post, I'm sure he can get it figured out.
