Re: Larger Throttle body
Here are my pictures of the install and the things I ran into. You might find some of these helpful. Some thing I saw as I removed it from the package was that it has ball bearings on the ends of the shaft. It comes with Alen Head set screws for the install and all the gaskets you need for the throttle body to upper intake and the Idle Air Control/Water Passage plate on the bottom including the bolts for that.
It is a very complete kit.
I found
a post on Camaro Z28 site of a guy who installed a 58mm in place of his 52mm stocker and saw a gain of about 7hp and 20ft/lbs. torque on back to back dyno runs. This info is just for reference because they have 8cyl. and we have a turbo...so not apples to apples.
On the down side: This is not just a bolt on. Some cutting is needed. Also a re-tune may be needed after the install as you are getting more air in the engine. ALSO... The aluminum plate that is on the very top of the throttle body does have different hole spacing from a stock one. If you wanted to put a custom plate on there like the ones that say "Intercooled" or have your truck number engraved on it...well they may not fit. You could possibly modify one to fit but as is it does not fit a plate like a stocker. I removed the sticker label and the plate it comes with looks nice although it is plane aluminum.
~Please note that I don't have everything tightened up in the pictures yet but it all fits as I mocked everything up. I have other work going on in my engine bay that prevents me from doing a final install it would be in the way.
FIRST: You have to enlarge the holes in the upper intake. It would be best in my opinion if you could do this off the truck but it can be done on the truck. If you do it off the truck you reduce the risk of shavings getting in the engine. To do it on the truck stuff some t-shirts into the upper intake (it will take 3 or so) to block off the inside to prevent shavings from going down into the lower intake. I spray the t-shirts with WD-40 so any chips stick to the t-shirt when they are removed. I also vacuum any chips on top before removing the t-shirts when done just to minimize the risk of chips getting down the intake. Be like a surgeon and count the number of rags you stuff in there and count them on the way out so not to leave any in there and shine a light in there too to check again that you got everyone out.
Take the gasket that was supplied with the 58mm Throttle Body and place it on your upper intake insert the bolts to insure alignment and use it as a pattern to scribe a line on the inside of the gasket holes to mark the cut line for the enlarged holes.
I used a carbide bit with large flutes that works well on aluminum to cut close to the scribe line.
I did the finish sizing with a Sanding Flapper disc as it slowly sands away to the scibed line and leaves a nice finish it is much more controllable than the carbide bit.
Here is the Long Shaft Die Grinder I used (Harbor Freight). The bits are 1/4" shafts. Any Air or Electric Grinder will work for this.
Here are the holes enlarged.
Just keep placing the gasket on and checking until you have a good match.
Place the throttle body and gasket in place with the bolts and rotate the blades open to make sure you have a good match.
NEXT: Prepare the throttle body for install by swapping over your TPS (Throttle Position Sensor)
I also swapped over the PCV hose to the lower rear nipple. I also placed JB weld into the upper nipple to block it off and ensure that if the rubber cap gets a hole from age it will still be blocked off with JB Weld and will not develop a vacuum leak.
Remove the bolts from the throttle cable linkage on the stock throttle body linkage.
The nut/bolt sized are 10mm and 13mm if I recall correctly. I drilled out the two pegs on the supplied throttle linkage of the new throttle body and enlarged the holes to fit the bolts from the stock throttle body linkage to make it fit. Install the linkage. I chose to glass bead and paint the linkage black at this point and I also applied red loctite to the bolts to ensure they would stay put (optional). When you remove the linkage from the new throttle body the spring on the shaft will release and that will have to be rewound to make the throttle blades snap back on the spring when you reinstall the linkage. Check for correct tension of the spring when you put the linkage back on.
I noticed that when the linkage is put together there is a bolt that hits the idle set screw tab on the front of the throttle body. See red circle on picture. I clearanced it with the carbide bit. I guess you could bend the linkage forward a bit as an alternative.
Also swap over the Idle Air Control (IAC) Plate to the new throttle body. The kit includes new screws and a gasket for this but you can reuse the old ones if you prefer they both fit.
Continued on next cell...
