largest turbo question
MrNurse
i'm no homo
curious, what is the largest turbo that can be ran in the factory location with out having to remove the a/c?
jwaller
Evil Genius/SyTy Guru
Re: largest turbo question
I've done a PTE 74 Q trim. it's now running around town here tearing up the streets.
sy#2716
SyTy 4 Life
I do not know the exact size but remember that robert from sweeden had a huge one and still had ac on it a while back
PPI Typhoon
DIY Madman
I have a T76 without removing the A/C, but I did have to use a spacer.
You can see the clearance.
sy#2921
BAMF
No spacers? I was thinking of doing this turbo on the built motor i have started but wasnt sure if it would clear. DO you have any more specs on the turbo?
It's just a six
Super Member
How do you like the T76 turbo? Turbonetics?
Have you run it at a track?
Sure is a tight fit!
MrNurse
i'm no homo
wow, thats a big a$$ turbo!!!!! ok, that is a little bigger than i was thinking of going with. i am thinking one of the 60s not sure which one though.
Timbo
SyTy Stalker
Robert had a GT45R on there without removing the A/C, but I don't think it was stock location.
PPI Typhoon
DIY Madman
I like it, but it's on stock motor, haven't run at the track. It's pretty laggy with a stock stall, but being a ball bearing turbo, it's not as bad as you would think.
Probably will never know what it's like as a V6 being that I'm upgrading to a 3rd Gen V8, either a 5.3 or 6.0L and putting that turbo on it (with an exhaust housing swap of course).
PPI Typhoon
DIY Madman
denny said:
What stall convertor you use with a PT76?
It's stock.........wanted to get the conversion done before I tackled the motor, but then decided to make a change to an LSx motor with the turbo, so I'm sitting on the truck for a while.
sy#2921
BAMF
PPI, what downpipe did you use? Did it cause any other clearance issues with that small spacer?
PPI Typhoon
DIY Madman
I had a local fabricator make it for me. No other clearance issues really. It all fell into place for me.
PPI Typhoon
DIY Madman
sy#2921 said:
I was hoping you were going to say pte but thats ok
It's very close to the type from Mike over at RPM...........and honestly if I were to do it over, I'd buy it from Mike instead.
