leaf spring rebuilding
hrodgmc
Re: leaf spring rebuilding
I've tore them apart, but I've never seen replacement bushings or clamps. They can be a PITA to disassemble.
bonesdmz
In Mother Russia Typhoon drives You!
Dunno about the clamps, but bushings are readily available at Rockauto.
ziembic
What are your hopes in rebuilding? Do you mean swapping out the bushings? And the clamps that you are referring to: Do you mean the u bolts to clamp spring and axle together or do you mean the little clamps that go around the leaves in order to reduce chatter? The u-bolts can be had at any parts store, the clamps can be had from the lift kit companies for situations where leaves are added to the pack. Once you think about the hassle of pressing/torching out the end bushings, I would look at a set of bell techs.
bezerk
putting new bushings in is not that big of a deal if you got a press, but i wouldn't take them apart
TY0618
I've done them on my Jimmy. Not that big a deal. I used a vise once, and once I changes a broken leaf on the truck. Get a new centering pin, new "U" bolts, and a new clamp to hold the springs together. Any spring shop can make them up for you. If you can, bring them in a sample of what you want, and they can make them.
warmpancakes
I found a place here in detroit, they sell all the stuff I need, the springs are bell techs but they arent powdercoated like bell tech says and the look like poo and yes im that OCD . so Im taking the springs apart powdercoating them and rebuilding them with new bushings and slip plates
