Leak down test results.
BMFB
Not to scale
Re: Leak down test results.
also you have a few differant threads going on about your issue so forgive me if I missed something, but you mentioned that when you took your 'exploded' turbo off you saw oil coming out of the even bank side of the port, have you taken a look at the plugs for any sign of oil?
well, we've all been though that, hell I rebuilt my motor twice last year and started practicing on the trans, lol
You dont understand. You haven't been here long enough. There is no "been through that". For him, it just keeps going it seems like lol
bezerk
i think i asked you this before Tytillidie, but you say you got 6'' eagle rods? normally they are 5.7' i believe? what is your CR?
BMFB
Not to scale
#2 and #5 had oil on them. The rest looked pretty clean.
Thats not good, its strange you lost all of this at once, along with your turbo.
that does suck, I know I've only been here a couple years, I couldn't imagine going through the last year over and over again. I hope it hasn't been that bad.
TYTILIDIE
METH HEAD
My bad Renee. They are indeed 6" rods but my forged crower crank has 2.1 rod journals. My compression ratio is 8.5:1. Or 8.3:1, one of the two.
TY162
Today I ran across a standard bore block with cross hatching still visible. It's been sitting for awhile but the cylinders were greased. Price was $200. Something you would be interested in or do you want to reuse your +.040's? Supposed to have been a merc. cruiser motor. 2 bolt, roller lifter non b/shaft block.
bezerk
thanks, but you mean offset or just journals? english is not my native language, but with that you mean bigger pins(tabs) in the crank? if so the length wouldn't remain the same?? no?
TYTILIDIE
METH HEAD
They may be offset. I know it wasn't offset ground like some stock cranks have been done,. This crank came this way.
Brassmonkey
Cruzin' Mel Man
Already being talked about around here. Mike is the man.
So in the last month or so, a cracked bellhousing, a destoyed turbo, a FUBAR engine and a grudge match with some Terminator/RX7 owner and some suicidal woodpeckers to boot :D
They will tell stories of your legend, Mike!
AUSyTyIN
Unbusted $#it box
Its just a damn shame I didn't get to race the RX7, my fault entirely. At least I got to race something though
<a href="http://imageshack.us/clip/my-videos/832/c24i.mp4/"><img src="http://img832.imageshack.us/img832/8918/c24i.mp4.th.jpg"/></a>
Not with that link you didn't...
*edit: damn, you just fixed it
**double edit: wtf were you racing? BTW, you friend laughs like Tickle me Elmo :lol:
TYTILIDIE
METH HEAD
Charger SRT8 mods were:
Cam, Underdrive pulley, Cold air, Ported manifold, Ported Throttle body 3500 Stall, Gutted Cats and Mufflers, 91 octane, and 62 lb injectors Thats it. The mods Ive chosen respond great on the nitrous. I'm back on E85.
The only things you did not get when we raced were the cut outs, which for some reason are worth 2 tenths. E85 and Nitrous.
Posted Image
For what I have done, I don't think it was that impressive I beat the guy. Perhaps had I not had a chewed up turbine wheel and seated rings maybe it would have looked different. But I try not to make excuses, the truck still felt better than ever so I'll stick with saying my Ty isn't fast enough yet. Maybe next time.
It was after this race that the truck started to smoke really bad. When I pulled in to the garage I had to leave it open for about ten minutes to let all of the smoke air out. And this guy called me out on the local forum, once my Ty is done we are going to run with him on spray.
Syclone22
1-16%
2-25%
3-33%
4-45%
5-76%
6-20%
I couldn't tell where the air was leaking, I couldn't feel air coming from anywhere but I did hear it. It was muffled, I assume that means it was coming from the crank case?
Sorry i did not read the last post if you were using
nitrous you are looking at possible melted pistons it
happend to me to using a 2 stage with hi boost !!!
qbnkiller
Conflaguration Specialist
what are you using to tune Mike? Are you on $59 or something else?
Quickstop [UK]
Combating adversyty.
So are you tearing the motor down soon? Any idea on what might have been going on? What destroyed your turbine? Was it a piece of a piston or a valve?
Hope you're up and running soon Mike.
RealFastV6
@jb_and_his_coffee
I'm calling "edge of a piston" but we'll see.
Super bummer.
Beavis
Still plays with trucks
I see your "edge" and raise you some broke ring chunks.
