Lean Spike
denny
I am having some lean spike , not sure if its something I should worry about.
The logs are about 8sec each, so the spikes are for a fraction of a second.
I think its the alky pump, when the alky presure reach 100psi, the pump stop and then start again after the pressure drops.
Its a T72, BS3 and Snow alky controller, 3 M10 nozzles with shurflow pump.
I am at 23psi & 20* timing and want to get it to 25psi & 25deg timing before I go to the track.
Denny
NecroWolf
lost marbles member
Re: Lean Spike
i know lean is bad, i lost a piston to it. as far as you're concerned it probobly depends on how lean it gets
jwaller
Evil Genius/SyTy Guru
Re: Lean Spike
get rid of the crappy alky system and get a real one that doesnt cut off and on. thats dangerous.
MIGHTYMOUSE
Turbo F body guy
Re: Lean Spike
you need to do a better job of holding that bitch to the floor! looks to me like you are rolling off the throttle a bit previous to each lean spike?
i have the same controller as you, what are the settings? the pump should speed up and slow down with boost, not turn on and off???
is your fuel pressure in question? you are upper 80's on your injector, can you turn up base fuel pressure without having it fall back off under boost?
denny
Re: Lean Spike
I do test run on an entrance ramp onto the parkway, its the only place I can find close to where I live. I am launching with 0 boost becasue there is a small bump on the road, that's why I am lifting off the throttle.
Alky set to come on around 6psi, upper 80s only around the lean spot, its back down to 60s every where else.
I run the alky out of the tuck using an air pump simulating boost, just to see how its working, using my intake pipe with the same nozzles. The pump don't run all the time, it runs until the pressure in the alky lines reaches 100psi, then sop. It start back up when the pressure drops below 100psi.
Thanks for the input, I have a lot more testing to do. Maybe backing off the throttle is what causing the lean spike.
MIGHTYMOUSE
Turbo F body guy
Re: Lean Spike
ahh... got it.
you said you have a snow controller but a shurflow pump.
you have the wrong kind of pump, yours has a built in pressure switch that shuts it off. obviously you don't want that.
find a way to bypass it or buy a snow pump. call them they may even tell you if there is a way to bypass it.
denny
Re: Lean Spike
I got those same lean spikes at the track, it got be something with the tune. This is a 11.8 @ 118 run.
Re: Lean Spike
Is it happening right after a shift? Hard for me to read the data/charts.
I would look at maybe some Decel, Accel, tables and their qualifiers. Not familiar with your system, is there a delta rpm change that kicks in one of the above?
WyoSyclone
Re: Lean Spike
I would think it may almost be some spurious artifact cuz of the short duration... Code59 has one of these that we just have to overlook....
I would take a look at your injector BPW and Wastegate DC immediately before and after the spike and see if you see either of them change radically before, during, and after the spike... it's hard to imagine that an engine could truthfully produce a spike of that magnitude and that short of duration, then instantly recover...... just my :2cents: :D
denny
Re: Lean Spike
Yes, right after it shifted to the next gear. There are a few settings, I got to figure out which one controls this.
Re: Lean Spike
Can anybody download BS3 softare. Be glad to look around if you can send me some files and I can download the software.
I am suspecting a dRPM or dMAP might be it, just a guess though.
denny
Re: Lean Spike
Sorry Jeff, I don't remember if reply to you on this. Yes, anyone can download BS3 software (http://www.bigstuff3.com/index2.html), its just an exe , maybe some dlls, small files.
If you want to look at bs3, I can send you my tune and logfiles.
I kind of forgot about all this problem since I haven't drove much since June. John at BS3 had told me to add fuel where its leaning out, I think I had done that already my current tune.
Planing on going to Etown this Friday, will see. I am runing 93 with meth.
