Little help w/ Identification...(Pics)
willyson
trollin'
Does anyone else have this switch on the left side above their lights? I can't seem to figure out what it does.
Ok, in this one there appears to be a plugged line on the top. Is this supposed to be plugged on a stock vehicle? Where does it go to?
Thanks in advance!
12secondSY
Syty Killer :(
Re: Little help w/ Identification...(Pics)
I dont think that switch is stock and Im pretty sure that line is supposed to be plugged
12secondSY
Syty Killer :(
I had 2 switches there though on my sy and I put them there for TCC lockup and for hotwiring my intercooler pump
willyson
trollin'
i didnt think it was a stock switch. what do you mean by tcc?
Captain Morgan
Moderated User
torque converter clutch
and yes, that line on the throttle body is supposed to be plugged.
MRKING
New Parts for Old Trucks
That also could be the valet switch to an older clifford alarm .
Jer
Don't taze me bro!
Does it run like poo with the switch one way or the other? You'll notice at low speeds and part throttle it will bog down and stumble when shifting like you shifted gears too soon in a manual car and then drop the clutch w/o slipping it at all. If so, TCC lockup switch. Could be many other things otherwise including nothing at all but a switch that was once used or was gonna be used for something.
The joys of buying used. :tup:
VermontTy
Support Our Troops
That plugged line runs to the passengers side valve cover and attaches to a PCV valve. I guess it doesn't hurt anything to have it plugged; you just won't reburn the crankcase vapors.
Captain Morgan
Moderated User
WRONG, but thanks for playing.
bezerk
the line from the pvc system is right under it.
the line that should be plugged off is for warming up the lower intake on some different engine setups.
Captain Morgan
Moderated User
T-56 said:
Maybe now you won't rag me so bad about my 6-spd...
of course I will, what else am I gonna do? :rotf: at least whoever did yours took care of the boost lag problem :tup:
