Ok, last night, I went to Davids house to fix his belt, and run a couple of datamaster runs.
http://bellsouthpwp.net/o/s/oscar_ca/David/david.uni
The car is setting a DTC for TPS error. I think there are two things that could be causing this:
1. There is a leak around the EGR, cause some scientist forgot to add a new gasket....
2. On most GM cars I know, TPS Voltage at WOT is 4.5 at most. David's car does not even reach 4V according the Daatmaster.
Also the car feels like a complete dog... I think it is that leak that is causing the boost leak also, cause datamaster at most only sees 10lbs of boost...
SO whatdo you guys think?
