Long Crank
Foot Performance
Alright i have just had my syclone for about a week and it has been starting like this the hole time but i think it is still taking to long to start i have not done any thing i was thinking cleaning the valve body and IAC bore and maybe a new motor just becuase
30k truck all stock except for waste gate
thanks for the help you guys are the best croud to run with thanks again
Re: Long Crank
Check fuel pressure. Fuel pump runs for 3 secs with key on. You can prolly hear it. If it's not doing that then the motor has to crank to build oil pressure and close an oil pressure sw to deliver fuel.
Daryl H
Re: Long Crank
The ONLY thing that worked for me was changing the fuel injectors. I did change or clean everything.
Hope yours is easier to fix
gjp
another post whore
Re: Long Crank
my truck is wierd. when its cold it starts up fast. when warm it takes longer to start?? New starter and battery helped.
