Looking for a test pipe
George Blake
DONATING MEMBER
I have an old ATR stainless cat back system for a Typhoon.
Trying to find a test pipe to replace the cat until I can afford to get a 3" cat converter.
My exhaust has a necked down area right after the converter that blends into the first downward bend.
Did ATR make a test pipe?
Is there a standard test pipe for this setup?
Thanks!!!
TYTILIDIE
METH HEAD
Re: Looking for a test pipe
Thanks!!!
You could make one for about $20 or less. Not sure if you ahve a wleder or even know how to weld but thats what I did. Piece of cake.
Loeryder
I have a couple things that might work.
One is the 3" extension for the ATR DP that mated the 3" ATR DP to a stock converter.
The other is a test pipe exactly as you describe that replace the stock dimension cat with a 2.5 inch straight pipe. It has the 2 bolt clamp/flange on one end and the slide on the other.
Make offer for either pipe as I am not using them.
