Looking for BOLT-IN muffler to replace cat/test pipe
Tooky
Serious about performance
Since doing the Vortec heads and 218/218 cam, the truck got a lot louder so I'm lookin for an easy way to quiet it down - two mufflers. Right now I have the PTE 3" stainless downpipe, PTE 3" stainless test pipe using the stock rubber "post" cat mounts of course, and finally a 3" stainless ATR Pitbull muffler & catback.
Are they any mufflers that you guys recommend that either bolt in place or that I can have fab'ed to bolt in place of the test pipe (which has identical dimensions & flange to the stock cat)? Cutting or welding the PTE Downpipe or ATR exhaust is absolutely out of the question.
Re: Looking for BOLT-IN muffler to replace cat/test pipe
I don't know how this applies to our truck, but one of local Corvette seasoned racer swore by Borla Racing mufflers to use in front of muffler (ie in place of cat) to reduce resonance/exhaust noise.
NOJIMMY
...I may be wrong (as its been awhile) but I believe Bob Galla found a really good muffler
after several mistries to reduce the noise outside/inside. Its particularly annoying in a Typhoon, where
resonance makes thes sound worse. Even dynomat didnt help that much as the constant
"drone" kind of drives ya nuts.
Also, I did a test myself with borla components vs ATR and found the former to be
more restrictive. I confirm this at the track, and later resold the system
to another Typhoon owner/friend who wanted a quieter vehicle. Just mentioning, as
backpressure can sometime be an issue with certain exhaust mufflers/cats.
Let us know if you find anything newer/better (again, my experience may be "dated").
-Larry
2kwik4u
Resident slow guy
I talked with a Magnaflow rep at SEMA about 5 years ago. He told me the dimension to be conscious of when reducing overall decibels was the length of the muffler. The longer it is the more it will dissipate the noise. I would think you could have the cat removed from the truck, and take it to an exhaust shop and have a Magnaflow round muffler welded into that pipe that is about the same length as the pipe, and that should quiet things down significantly without hurting flow much at all (if any). Should also be a pretty cheap solution, I'd guess under $100 total investment.
Just a thought.
