Looking for help with a DM file
raman117
Hey guys, I've got a 93 Ty with the following mods:
Walbro fuel pump
hot-wired IC pump
Julio's alky kit
3-bar MAP sensor
Hood tuned chip
RFL BOV
I just installed the 3-bar MAP, alky kit, and chip tonight. However, I don't think it is running quite right. I'm only maxing out at around 12psi of boost, and at high RPM's the tach is fluttering. I'm running 91 octane fuel. Here is a link to the DM file: http://www.mediafire.com/file/e8a6yq7ltv0x1eq/8-23d.uni
Here is a screenshot:
Is it normal to be above 100 for the injector duty cycle? I have confirmed the alky is working, as the light turns from red to green when I'm building boost. It just seems like something isn't quite right, any ideas?
WyoSyclone
Re: Looking for help with a DM file
I just looked at the file. If I were you I'd do a log with the alky off so that we have a baseline to compare to. Any tune I've seen Hood do has been pretty much on the money. Your boost is all over the map which makes me think you're probably blowing out the spark, which is causing the 'fluttering' you speak of.
Get that baseline log done and post the link up and I'll take a look.
raman117
Thanks, I'll give that a shot. I forgot to mention that I also just replaced the cap, rotor, wires, and plugs. I used NGK UR6's gapped at .028, Taylor wires, and Standard Blue Streak cap/rotor.
WyoSyclone
Yikes... that looks pretty bad on the KR. Which of Hood's tunes are you running?
I would think you've got something mechanically wrong. (EDIT .... ooops I see you already did this .....Check out the plugs and plug wires/dizzy cap and rotor.) Recheck the motor for top dead center and correct timing, and check every single vacuum line/connector for issues.
Do you have a fp gauge to make sure fuel pressure is following boost? Check motor mounts to make sure engine isn't torqueing over.
Your injector DC was quite low on this run.The KR begins at the onset of boost and follows the boost all the way up.
Check all the mechanical stuff and see if you can find something wrong... then we can move on.
WyoSyclone
If you can send your BIN over that would help...... rputman at bresnan.net
Your O2 mv's are really bouncing around. How many miles on the Ty and have the injectors ever been pulled and cleaned?
raman117
Thanks for the quick response, I sent Hood an email to get me the BIN. The Ty has 43,900 miles on it, and I don't believe the injectors have ever been cleaned. However, I've never had this much KR in the past. I'm wondering if I should try putting the stock chip back in and doing a run to rule it out? After I did the ignition upgrades, everything seemed to be running well, although I did not do a datamaster run with it.
WyoSyclone
Yup, I'd put the stock chip back in and see what happens with it. Double check all your spark plug wires as well. Run it at night and see if you can see arcing anywhere, and make sure the coil wire is really inserted all the way down into the dizzy cap.
The Bronze
I noticed a couple of things, maybe not related:
The boost isn't steady, but I think the length of time it takes to spool is more of an issue. The boost comes on super slow. This looks like it isn't too fast off the line, but I didn't see where you were complaining about power, just the tach flutter?
IAC position is around 75-85 depending upon the file. Why is this so high? Retarded timing would require more bypass air, as would an exhaust or restriction.
Idle vacuum is low. A WB would be nice, cause I am wondering how much alcohol you are actually injecting. It doesn't appear to be much, you are only getting around 1* more timing out of it. What are the settings? (More curious than anything else, alycontrol system just came in the mail tonight).
sytyguy
Moderated User
I would def. put the stock chip in with the 2bar and make a datalog. I'm not perfect and neither is my burner, so a goofed chip is def. a possibility.
Otherwise, do this for me. Change the spark advance line on the graph to boost and the speed line to TPS %. Then run a vac line direct from the turbo to WG (bypassing solenoid) and make a run with no alky again (using the 3bar MAP and chip). See what the datalog shows. Also, make sure that DM is set for 3bar display units......the above screenshots indicate that you're still set for 2bar.
raman117
Thanks for all the help guys, it's greatly appreciated. After work today I'll test with the stock chip. All this stuff started happening after my upgrades, previously I would get around 15psi with no knock (running 100 octane). Unfortunately, I don't know if it's because of my ignition upgrade, alky, chip, etc.
raman117
To clarify, would a boost leak exhibit these symptoms? Obviously I had to notch the clamp and rubber between the CAC and intake.
sytyguy
Moderated User
Did you bypass the solenoid? If so, then that's what your base spring pressure is (assuming rod is properly adjusted). That's what we were expecting to see (8-10 psi) for the stock spring.
I'm not near DM, right now.....is the boost steady? What does KR look like (in relation to what you've seen in the past and what you saw with the 3bar chip and map)?
The chip is still suspect......and even the MAP is. Is there anyone local with a 3bar map that you could borrow to determine if it's bad (I've seen a rash of faulty 3bars lately from MSD and other suppliers)? I'll gladly redo the chip if we narrow it down to that.
WyoSyclone
Well, the KR is much lower with the stock chip. The KR is still following the boost curve though. Can you hear the knock? Have you checked for all possible causes of false knock (downpipe, fuel lines, soft/broken motor mount)?
raman117
I pulled the 3-bar MAP out of what I believe to be the original GM box. Both this and the chip were in the glove compartment when I purchased the vehicle from Skata. Unfortunately I don't have another 3-bar MAP to test:-( I did not bypass the solenoid, I simply installed a 2-bar MAP, installed the stock chip, and turned off the alky. We have pretty crappy gas up here, the knock present in these DM files seems consistent with what I've seen in the past. If I run race fuel I'm fairly certain the knock would disappear. Dig lives a few hundred miles away, I could see if he has any extra 3-bar MAP's I could borrow. However, does this explain why I was only seeing 8lbs of boost? I just noticed the IAT seems really high (169*), generally it's around 120*. I did notice the coolant may have been a bit low in the intercooler, tomorrow I'll add some more. Here's a screenshot:
sytyguy
Moderated User
Please, go into Setup >> Display Units and check the box for 3bar MAP cal. and while you're there, check the boxes for degF for all temps. Now, let's establish some baselines. Toss the stock chip in with the 2 bar MAP, bypass the WG solenoid and record a run.....let's see how steady the boost is and at what level it's running.
If you're getting erratic boost, or it's way to high or low with the solenoid bypassed, then we need to remedy that. Likewise, if you're still getting heaps of KR with the 2bar setup and the solenoid bypassed, then we need to fix that FIRST. No chip or MAP will fix these issues if they're present under these conditions......quite the contrary, they'll often amplify the negative aspects of a tune and make problems worse.
sytyguy
Moderated User
Looking at the DM files, the most alarming thing ATM is the IAT temps. Verify coolant level and pump operation. If running the stock chip, remember that it won't command the pump on with the key like the chip I burnt for you will.
raman117
Thanks, I'll give that a try tonight. I was hoping the alky injection would take care of the KR I'm having due to the horrible gas. Is it ok to check the "3-bar MAP" option in DM even if I"m running a 2-bar?
raman117
Skata hot-wired the pump so it runs all the time, I'm going to fill the CAC tonight after work.
