martygar8
syclone #1322
hey bro i was reading and going through the site and searching for some other problems that i can fix, and found someone talking about fuel pressure, that if to much fuel pressure can cause idle problems, well i check my fuel pressure, and if i remember correctly the fuel pressure was close to 55lbs on idle and 60lbs when i push on the gas, which ive heard is extrembly hi. And that the normal fuel pressure should be about 38lbs to 40lbs something like that is that correct, could that be causing my idle problems! since you helped me LIL QIK let me know bro and thanks for all your help!! :tup:
