Mine has been replaced with an aftermarket chip.. I believe its a KennyBell chip ive done some searching and seems its not a good chip to go with.. at the moment I was wanting to replace it with a stock prom to see if it solves my problem.. Its running insanely rich.
I thought the factory eprom was attached to the kenbell chip just like all other chips and adapters!
http://youtu.be/w7-trGF2bms
KB did not use an adapter, the were a seperate memcal. ATR chips were single memcal solutions as well. One of the problems with KB was that Memcal that KB used wasn't even a SyTy memcal, so even if you bypass the EPROM portion of the chip with adapter the esc spark retard portion still doesn't work.
No... you said that the esc circuitry was not the same in the Kenne bell chips. You are 100% wrong.
Also I have a few stock chips and will take yours in on trade If you want.
I'm pretty confused now, I just got off the phone with the GM dealership and it was the same guy i spoke with yesterday in person. I explained to him that the Eprom is not what I was actually wanting to replace and that I just need a factory chip and I proceeded to tell him that I was told the Eprom is what the chip goes into. He cut me off and said no the Eprom is the chip. We went back and fourth for min but he held his ground on the fact that the Eprom is the chip.
So ill try my question once more here just so I can further pursue finding the part I need lol. At the moment I have a KenneBell chip and want to replace it back to factory for the time being. Would I need to replace the chip or the Eprom? I know some of you already have tried answering it for me, I just wanted to make sure everyone understood what I'm after.
Thanks
Ok. I hope this makes sense. there are 2 sides to a memcal. one side is your eprom (black). That is what is modified in tunerpro or datamaster to tune your truck (fuel map, timing, boost,ect). by using a memcal adapter. The other side of the memcal (white circut looking thing). we dont mess with that. When people say thay have a chip. they are talking about the eprom. When other people say I need a chip. they are talking about a memcal. The word chip is highly misused and confuses the shit out of people. Here is a video that might help with what I am tring to say.
http://youtu.be/RroPpf1fu-A
