Looking for Ultimate info- BG?
Sy Guy 0024
Can anyone tell me what version of the Ultimate I have (ie stock heads, or heads and cam chip, etc)? It's part number c3b16v6. This was purchased by the previous owner of my truck, hence I have no info on it.
Reason I ask is that my sy has been running terrible. After a COMPLETE ignition tune-up, heavy breather and I pulled the 3-bar and the Ultimate and went back to stock. The off-idle/tip-in stumbles and piss-poor idle quality I had been experiencing were gone. The truck didn't pull as hard WOT, but the overall driveability had improved 10 fold. Thinking it might be a bad 3-bar, we pulled the good one from his Ty and swapped it back on with the STG. No dice- same driveability probs as before.
The prior owner informed me the truck had bigger injectors, ported atr heads, and a cam package. Since it ACTUALLY has stock injectors, stock-style (not vortech) heads, and a mild cam, that left us wondering if the dildo purchased the wrong Ultimate chip (ie heads and cam chip- or gasp, the 50lb chip!). That could have a BIG effect on performance, huh?
If anyone could help me out, I would really appreciate it. BG?
Corbin
smeagol
that's a stock injector/stock motor calibration, version 6
the other truck with a 3 bar, did you try his chip? (I'm assuming it was 3 bar and had one of my cals)
a cam could cause weirdness with the drivability, the stocker might be more forgiving, the chip could be bad. what was your fuel pressure at? The stocker can run with a lot lower fuel pressure than my stock injector calibrations. If you ran it at stock fuel pressure levels, it would cause the issues you are seeing (poor idle/drivability).
Sy Guy 0024
Man I was hoping it was the wrong chip :-?
We didn't have time to take his dash apart to pull his Ultimate, or we would have. It's one of your cals and it runs perfect.
The cam is a crane part no. 18hr00003, 194/204 duration. I thought that was a pretty mild grind? Fuel pressure is set at 50lb static, around 44 w/the vac line hooked up.
Think it could be a prob with the memcal then?
Corbin
CLONE
Sounds to me like a vacuum leak possibly, or the cam is altering the vacuum quite a bit. I've noticed BG's 3-bar cal's seem less forgiving of vacuum changes from leaks/cam's than stock or other cal's like ATR's.
That cam #, is that a special grind? If so, what are the specs off of the cam card?
heavy breather
FBI enforcer
The truck was running pretty good with the pit bull in it. That's what it was test driven on. It runs good with the 3 bar, just really bad idle, and a horrid hesitation. I want to pull my memcal and put it in his truck just to eliminate that issue. Also, we are trying to record a few DM runs to try and nail down the problem. My latptop isn't being very cooperative. We have completely eliminated any electronic/ignition issues, and the FP is tits. I am really not leaning toward vacuum myself. The cam just seem really mild to cause big vacuum issues. Besides, the gauge is a solid 18" at idle and seems to be comparable to my TY throughout the entire RPM band.
sytyguy
Moderated User
Chris' (Lee) truck had a similar problem. Ran fine on 2bar/stock setup and like crap on 3bar/Ultimate. I burned T1-18 onto a stock prom I had spare and still nothing. Put the 2 bar on with ultimate and idled great. Put 3 bar on with stock and ran like crap. All in all, turned out to be a bad MAP. Not likely that they go bad too often and not likely the issue with this case, but don't rule it out. Try a known good one and be sure.
Michael
