looking over the speed pro log
FLSY2730
i was looking over the speed pro logs we did at moroso and the air temp reached 149.7 after the full pass, is this good with the cas unit, and the injector duty cycle got to 73.4%, and the VE% reached 84.7%, and the tps reached 75%, and the MAP kpa reached 263, and the biggest o2 correction was -11.7 at 133 kpa. What do you guys think? Good/bad? One good thing was 0 knock retard. jack
smeagol
Many things to take into account here.
263 kpa is ~23psi, FWIW. Was that a spike? or was that the full run? Can you send me the log of the run?
What was your MAT at the beggining of the run? Single core or dual? Do you have a scoop on it? What was the temp that day? What was your coolant temp?
That TPS should go higher than that, I'm not sure how they coded the TPS in the FAST/Speedpro though. Make sure that you are getting full WOT at the throttle blades.
VE isn't really crucial, duty cycle is a good thing to watch, but some info you really need to log is the desired AFR, the *actual* AFR, and your correction.
Also, as I've told many people, that knock retard value in FAST/Speedpro is not going to be 100% accurate, but it can give you some feedback. It is using a Buick ESC module, on a highly modified motor that it was never designed for (not even the right make).
FLSY2730
Brian, it was hot that day about 85 maybe hotter , we were sweating just waiting between runs. The temp on the MAT started out at 105, the 23 was a spike , the run was mostly 21-22. The intercooler is single core and i will be putting a scoop on it. The truck normally runs between 160-175 coolant temps. I will download that or all the runs and send to you if you want. thanks jack
smeagol
Ok, sounds about right for such a hot day, that's how it is in Chitown now too :wink:. I bet you'll drop MAT temps considerably with a good scoop. Try to use the Container Store setup on the CAS setup.
If you have a fast enough machine, log your runs using WinSP/FAST, as it can log more sensors, for longer duration.
I'm curious to see the logs...
geez, i sound like a fecalologist...
_________________
Brian Green
www.chitownsyty.com
syclone160@yahoo.com
<font size=-1>[ This Message was edited by: Stanley Spadowski on 2002-03-25 22:47 ]</font>
