Loss of boost....
TxSy1430
Ok so I'm at the local 1320 Saturday and noticed when I launch the truck it quickly goes to 20psi which is where the boost controller is set. Now it will hold 20psi until about half track and then it drops to 11 or 12psi then holds there. I have no idea whats going on, has anyone had this problem?
It's just a six
Super Member
Re: Loss of boost....
Could be having massive knock retard,?????? that will lower your boost pressure.
More details on your truck would be nice :tup:
TxSy1430
TD06-20g @ 20psi, 50lb injectors, 455ci Waller air to water intercooler, methyl alcohol injection, billet TCI 2800 converter, stage 2 shift kit, MSD Digital 6+, MSD HVC II coil, Blitz boost controller, external wastegate, K&N filter.
dirtdemon
"mr. ghettowrench"
what about fuelpress ??
also check if ignition work proper ...
HTH,pat.
SyTyJedi
Jedi Council
Is your boost consistent with the controller off? What spring is in the wastegate?
I would check the ignition as well. Something isn't keeping up with the load on the engine.
Were any changes recently made to the truck? I have heard of problems with aftermarket ignition systems. What happens if you unplug and bypass the MSD box? Have you done maintenance lately like cap/rotor/wires/plugs?
What do your Datamaster logs show?
