lost axle c clip ??
berzerker
wookie
i'm not sure if this is possible or not , can the axle c clip fall off an axle after the retainer pin and everthing has been re-installed into the diff. . i did the rear ls1 rear brake conversion several weeks ago , everything seemed fine till this morning . then the ass end felt loose like a low tire or something . we'll got home and jacked up the rear . found that the right side axle slides in and out about 1/2 " and the left stays put .
gstacky
Re: lost axle c clip ??
I have had axles do that on more than one vehicle, seems to be a GM thing. C clip is probably still in place, just one side has a bit of play for some reason. My Avalanche does this, as well as some S-series I have come across.
ty166
i would pull the cover and make sure the clip isnt laying in the botom of the diff and the only thing keeping that axle in is the caliper. it could have slipped out and landed in the bottom of the diff befor you got the pin back in.
berzerker
wookie
thanks for the suggestions guy's , when i get home from work tonight i'll pull the wheel and brake caliper ,/ caliper bridge down and see if the axle slides out . If the axle stays put , i guess the clips still there ,,and i"ll just keep running it .
jpalmer
Uh, half inch??? if it didn't do it before, it should not do it now. your brakes are the only thing prob stopping it from coming out.
berzerker
wookie
clips still there . it's good thing i took a look though , the wheel seal was seeping . something for me to do this weekend - o joy-
ty166
with that much play im surpised you dont have a shitty/low brake pedal. you would think the axle would be pushing that caliper piston in if in fact it is a 1/2 inch of movement.
berzerker
wookie
we'll since i'm going to have the axle out this weekend is there anything i can do to take the end play out of the axle ? i.e. new c- clip , new axle ?
