BoostedSUV
help me find 5lbs of manifold vacuum!! My truck always idled about 18lbs of vacuum and held it steady... I was driving it home from work the other day and i noticed it was running funnier than normal. Felt kind of laggy just under normal driving, I started checking gauges and noticed I was cruising at 50mph in OD and only had 10lbs of vacuum. If I barely moved the throttle it would zero out. At idle it was was only pulling 12-15lbs of vac. I'm having other issues with my truck (whole other story) but I wasn't even boosting it at all so I don't see what I could have hurt??
I did my own version of the "bike tube" test and did not find any leaks, I pulled the intake manifold off changed the lower intake gaskets even though they looked perfect. I checked the lower and TB gaskets, both were perfect... I used my vacuum tester and checked every line that I disconnected right from the upper plenum. vac ball/hvac/cruise line pumped up to 25lbs and held it. Map/AFPR pumped up to 20lbs and very slowly bled it off, Boost gauge, boost controller, alky controller line pumped up to 20lbs and slowly bled off as well (normal?). The charcoal canister line off the TB would not pump up any vac which i think is normal, but I capped and started the truck with no change.
Truck doesn't idle high and IAC numbers seem to be normal. The truck will randomly idle up and when it does the vac goes to 10lbs... I'm thinking its something mechanical. Any ideas??
