loud injectors, 50's
Falco
Howdy,
I started to test my new combo with 50's and I found the new injectors really noisy. First I thought it's a valvetrain noise, but it's not there at idle only at acceleration. It's definately louder now than it was with the stocker. Anyone with the same experience? Or any other ida what could cause these that noise? As I let off the gas anywhere it goes away. So it's not there at idle and at deceleration...
TIA,
4C FED
Absolutum Dominium
I remember reading that you can induce noise by seating the injectors to deep into the injector bungs.
You might want to try to pull them up a little to see if this helps.
smeagol
I forget, one or the other, sy or ty, has slotted fuel rails for adjustment. Probably the Ty.. anyways.... it was along the same lines as what Rick posted. Let the o-rings absorb some of the vibration, rather than being jammed in there, is the thinking I guess ..?
Falco
Thanks guys! My injectors are sitting deep for sure... I remeber that I used a rubber hammer to put them where they are now. :eek: I know... :-? Gonna try to pull them out a bit...
Peace,
