Re: Low Boost DM File (SEL777)
Im using the blue spring wich yeilds me 14/15psi steady. I have no problem building boost either with a stock TC on a 14cm 20g, spools just as fast as a stock turbo.
Dig made it clear how the stock boost control solinoid is designed to work with the duty cycle programmed in the ECM. Hooking up the factory solinoid is not going to work.
No matter what spring is used in a 20 G 14 CM turbo, it will not spool as fast as a stock turbo & stock torque converter.:2cents:
There is & there will be a delay, you have to wait for it to spool up.
Once it (the 20G turbo) sees boost it is OK, but IMO, it's a bit lazy as compared to a stock turbo & even more so when running a stock torque converter that only brake stalls to 2100 RPM.
With a stock turbo I could hold the brakes & boost to 20 PSI or more,, & that's w/a stock wastegate actuator of what 6 PSI ?
So, even when the wastegate valve was open when I have brake boosted to 20 or more psi, it was not problem to boost @ all even w/the wastegate valve open & yes it was open.
I made it clear also,,, that you can hook up a different actuator & use the stock boost control solinoid, I ran it this way for years. My base boost pressure on my actuator is 15 PSI.
Yes, the factory set-up is more accurate @ controlling boost pressures, but just saying there are ways to get around this.
The main problem w/the stock boost control working correctly when boosting higher that stock or free flowing exhaust set-ups is the stock wastegate valve is too small & or the hole is too small to vent enough exhaust to control the boost.
It ( the factory solinoid) did control the boost pressure & @ different settings on my Ultimate chip.
All done in conjunction w/the 15 psi actuator.
This is my personal experience & my opinion.
