randy merritt
I posted this in my ongoing build thread, but thought I would post it here in a new thread because it was a real eye opener for me.
After I did a compression check, I discovered that Cylinder #1 had only 125 psi. All the others (except #6 which I did not check because of the annoying down pipe in the way) were right at 160 psi. I put about 3 tablespoons of oil in #1 and checked the compression again, but it made no difference. This lead me to believe I had a problem with the heads. The motor had no blow by at all. The truck still ran good, and did not smoke.
I put air pressure on the #1 cyl. at TDC, and you could clearly hear the air leaking from the exhaust. I assumed I either burnt a valve, or there was carbon build up on the seat.
The next day, I met with my buddy who owns a machine shop to see how much it would be to go through the heads if I brought one of them to him. He told me that it could just be carbon build up on the exhaust valve seat and to just spray water through the running motor. He said the steam generated by the water did a good job of cleaning out the combustion chamber. He said "I have seen a lot of problems fixed with a coke bottle full of water run through a motor". Well, I sprayed about a gallon of water through the motor by removing the air inlet at the throttle body and spraying it directly into the throttle body with the motor idling. I used a small pump up sprayer and sprayed a small amount at a time, letting the motor bog down slightly, then recover, spray more water, etc. I then retested the cylinder compression on the #1 cylinder. After running the water through the motor, the compression rose from 125 psi to 152 psi. I was shocked. The motor even seems to start and idle better, and it has more power.
This fix was much cheaper (free) and easier than pulling a head.
Tap Water. Thank you.
__________________
__________________
