Need some help with overheating
Again I am driving 120+ miles, low coolant light comes on, stop get gas etc, turn off, & it starts very hard after several attempts cranking. IC and radiator are hot but filled with coolant. I let the truck sit & idle thinking it would cool off but made the computer cut boost over 5 psi. After driving for an hour, 1/4 throttle, no coolant light, turned it off, let sit 15 minutes, disconnected & reinstalled ECM B fuse (on the right hand side), idle for 5 minutes to reprogram everything & everything's back to normal, full boost. Drive another hour and again same problem, sluggishness & hard starting. Let sit, disconnected B fuse, back to normal. What is the ECM A fuse on the left? Mine has a self resetting circuit breaker in it that gets hot after the truck has been driven. I started disconnecting this with the B fuse also. Is this the IC pump fuse, if not where is it? Where is the IC pump located? I didn't have this problem when I drove it 1400 miles from MI but now when driving 120+ miles.
