Low fuel pressure
akwilks
Mr. Keith
Last week, a fellow sytyer came by to check out why my truck would not accelerate beyond 4k. We checked the fuel pressure and it was a 0. After continuously starting the truck, it would rise to about 10. Adjusting the fpr didnt help too much either. After messing with the fpr enough, we finally get the pressure up to 41#. I have to start my truck at least 5 times before she starts and always wants to stall. Am I looking at getting another afpr or is there a bigger problem. I have a kb afpr. Can they be rebuilt? Thanks in advance....
Ty0279
Historically Significant
Re: Low fuel pressure
I don't know if they can be rebuilt...
1.) You could try another SyTy'ers AFPR and see if there's any difference.
2.) Try replacing the fuel filter if it's never been done or if it's been a long time.
3.) Your fuel pump may be on it's way out...if so, it's time for an upgrade to the Walbro 255l/h pump.
4.) I guess this could be a possibility...but are you sure your fuel guage is correct and the truck's got enough gas in it?
akwilks
Mr. Keith
A fellow Syclone owner had his truck and we tested the gauge on his vehicle because we couldnt believe my ty could run with so little pressure. I do notice that as I accelerate, it stumbles at the beginning then just takes off then bogs abit at the higher rpms(3.5k-4k). The afprs are 100 bucks a pop!! These repairs are killing me! I was going to put the stock one back in but I wont get the pressure needed for the phil long chip. I want to get her right one day so I can take her to the track before she goes into storage....
akwilks
Mr. Keith
I believe it has a stock pump in the tank with a hi flow external pump....could be a kenne bell setup or something similar....
TYTILIDIE
METH HEAD
Find out exactly what oyu have, check your wiring harness and relays. Do a FP test while driving, that s worth its weight in gold IMO. Let us know the results of that. I would actually do that first because that will tell you alot about whats going on, I doubt a bad reg would give you 0.
