low iac numbers- what to do?
Gnocide
turbo game burt reynolds
the iac is going through the range just fine but ,
when its hot and in park at idle instead of being 20-40 its 10-12.
its also at 18 in drive idle hot
so what causes it to be low and how do you fix that?
Re: low iac numbers- what to do?
If it isn't getting to zero you are fine, but the most common problem that can affect it are vacuum leaks.
Another thing if you just swapped out the throttle body it will change.
You can "adjust" it with the set screw on the TB, factory they are sealed but by now most have been removed. Just adjust so it idles where you want the IAC 30-40 is my goal, but again if you don't reach 0 or 255 then you are good.
Desired Idle speed will also change it, done in the chip.
ditto on what TTv8TY said, if you change to a aftermarket throttle body on the older tpi and lt1 engines it was always a hassle with the blades being to closed shut and needed to be tweaked open just a bit.
Gnocide
thanks for the input:
vac leaks are always a factor- i have the sport machines kit vac kit freshly put on- but still maybe.
also throttle body is stock so maybe gasket or maybe air leaking through side linkage.
bike tire test then to determine where?
