Low Voltage reading in ECM
I have a low voltage reading in my diacom. I have good voltage at the alternator, I ran direct power to the fuse, but I still get 12.6-8 Volt at WOT, along with a few other screwy things (KR with out knock counts and my BLM don't appear to work properly). I think the problem is my ECM itself.
Could the problem be cold solder joints? Should I tried reflowing the solder in my circuit board? Has anyone tried this? I am worried if I buy a new ECM it may have the same low volatge problem and nothing major appears to be wrong with my ECM.
jwaller
Evil Genius/SyTy Guru
this has been hashed out b4. check your voltage at the cig lighter and batt and alt at wot and check the actual ecm supply at wot. the readings from DM can and are often wrong or misleading. if your batt volage is dropping at wot thehn you have a problem.
most ppl that have reported this. (even me) have steady voltage at wot at the alt and batt. it's been said that this is just the inj drivers pulling juice.
Daron
Yeah, I found some time ago that different ECM's will report different voltages when used on the same truck. I recall someone a while back re doing the ECM B circuit to up the power to the ecm. Anyone remember?
I already did that mod. I just want to make sure everything is running 100%. My ECM seems to add Knock Retard at WOT without any Knock events, which has me puzzled. I was hoping more voltage at WOT may help my KR issue.
