2500avalanche
Well-known member
OK,
I just need some advice.
I Had a jack under the lower control arm, I took out the torsion bar adjuster bolt, and took loosened the ball joints, removed the hub, and spindle. I then lowered the jack to lower the control arm. It lowered, but not straight up and down, just lowered. Does this mean that there is no tension on the bar, and I am safe to un bolt the lower control arm and nothing is going to fly out? Just want to make sure!
:tup:
:tup:
