Lower heat exchanger?
jbone
Ive done searches all over the forums and the internet and I keep hearing about conleys/atr heat exchanger and dequick's heat exchanger but I cant find any place to get them. Do they not make them anymore or am I just not looking in the right spot. Im currently working out all of my intercooling/engine cooling problems and I want to replace that before it becomes a problem.
Loeryder
Re: Lower heat exchanger?
ATR sells an oversized UPPER intercooler that is way overpriced for what you get.
It also tends to punch holes in the AC/Heater box b/c it sits so close.
ATR also sells an AUX IC cooler.
That is the oil cooler/radiator, that sits in front of your stock radiator and gets plumbed in series with the stock CCHE. Adds fluid capacity as well as additional heat dissipation.
The Dequick lower CCHE is not made anymore, but it was a larger capacity aluminum unit that replaced the stock lower cche and bracketry associated with it.
vortecfiero
I keep seeing oil cooler in this post... ?
or is it the lower heat exchanger for the Intercooler system ?
craig
Ebay......they Have Upgraded Cche's On There From Time To Time.....just Type In Syclone.....whatever Is Sy Related Will Pop Up.....really Nice Unit ... Much Larger Than Stock And Will Mount In The Factory Location..
Loeryder
The Hayden radiator/cooler used in the ATR Aux setup is actually designed and marketed as an OIL cooler.
Not much difference circulating coolant/water vs oil.
Just trying to be politically correct when referring to parts, I guess.
jbone
craig
Im talkign about the lower heat exchanger for the intercooler
Vaders Sy
That happened to my Sy. I also agree with the first part of your statement.
